Solved! Go to Solution.
I don't know why this is marked as a solution PCC repair DOES NOTHING. I have a D6633 and I have not been able to use a USB OTG (either via a cable or a propper USB OTG pen drive) since updating to 5.1.1 on my D6633, I have done the repair, I have even tried different Firmware versions with NO LUCK.
My guess, Sony, in all it's wisdom has enabled it for some regions and disabled it for others. That's the only logical answer to some people being able to use it and others not.
WHY SONY DOES NOT BOTHER TO RESPOND TO USERS? It's beyond me.
So, thank sony for breaking it for you......
I use D6633 with firmware 23.4.A.1.264 Customized CE1 and it work's normally try that one and if still no luck contact to Your local support
@lokrsw
Will do, thanks
edited.... tried, tested, worked. CE1 rom has USB OTG, working in fat32 and ExFat, thank you.
Also, a friend @xda tested the PT version and it also worked.
