Usb otg support for Android 5.1.1
SOLVED
Sulleykassam1
Visitor
Im experiencing problems connecting usb drive to the xperia z3. The phone charges ok via usb. It also connects to pc via usb.
So i don't know what the problem is with usb mass storage connection!
Kindly assist
NB:
I did usb host diagnosis and found api support with question marks and also kernel had question marks.
Does this mean it has software related isssues then? Probably a bug and will go with the next update
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.PL.title
lokrsw
New
Use Sony Pc Companion for reflash, turn app on then Support Zone > Software Update
17 REPLIES 17
Lord_viridis
I think they changed the USB detection in 5.0 to accommodate the Z3+/Z4 etc etc.
Because these models have waterproof USB ports, they put the USB otg setting in
/settings/device connection/USB connection/ detect USB device.
Try that, although the Z3 has a different port, they may have just put the setting there to keep things continuous between models.
lokrsw
New
Check otg cable, I have no problem on Z3 Dual D6633 and android 5.1.1 f.w. 23.4.A.1.232.
Sulleykassam1
Visitor
Android 5.1. 1 does not have option for detect usb connection.
Just has media transfer or mass storage ( i have tried both) and install software to pc
I tried 2 otg cables and also the same cables work on another phone ( xperia z).
lokrsw
New
That's strange I have android 5.1.1 and it detect's usb mouse, keyboard or pendrive when I connect it.
Sulleykassam1
Visitor
Wow...now thats strange if you have 5 1 1 and can connect and i cant.
I used android usb host diagnostic app.. And found that my android api has question marks instead of yes. Even for kernel support mine shows question mark, while its supposed to yes for support.
I dont know if its and issue with my update and that its a bug on my phone.
lokrsw
New
Which app do U use for testing? It's probably issue when updating to newer version of android, try to reflash current f.w. once againg. If this dosen't help try factory data reset.
Sulleykassam1
Visitor
The app is usb host diagnostics
Sulleykassam1
Visitor
How can i flash the firm ware?
Please tell me i can do it without a pc...coz mine is just not available at the moment (lol)
lokrsw
New
I've run this app and it says Kernel - Claims Support Yes, Device detected NO, Verdict - OS support NO, 3rd party apps NO, but my pendrive show's up as normal and I can use it. Which f.w. do You use?
