Hi everyone
The issue can be solved only by a firmware update from Sony
The problem is with 2 system process which can only be deactivated but can not be removed and they causes the problem
Those system process are:
com.facebook.appmanager
com.facebook.system
Sony must react with an update or at least with a patch
Same problem
Error 505
Nothing works to solve the problem
@Bingsearch2017
Could you please post again your problem here
Hi guys
I found the solution, everything works fine now
First make a factory reset
When it's done do not install or update any thing
Open Google play store (don't apply any update)
Search and install Messenger it will pass
Then update Facebook it will pass too
Then you can install and update whatever you want
Enjoy
Hi Bbrohn
Thanks for the solution
Are you sure?
Did u try it?
Anybody tried it?
@ Bingsearch2017
Yes, that's what I did and all works fine for me.
Am failing to install facebook for android and messenger on my xperia z5. Had both apps installing perfectly before upgrading to android 7.0. What could be the problem? How do I solve it?
Hi,
Facebook complained it was out of date, so I tried updating it from Play Store and got error -505. Thinking that might help I removed it and tried installing again. It didn't help, and neither did a reboot.
Here's a log:
05-15 03:50:26.934 2483 2588 I ActivityManager: Start proc 12122:com.android.defcontainer/u0a41 for service com.android.defcontainer/.DefaultContainerService
05-15 03:50:27.031 12122 12122 I LoadedApk: No resource references to update in package alias:android.res.overlay_305
05-15 03:50:27.032 12122 12122 I LoadedApk: No resource references to update in package alias:com.sonymobile.dummy
05-15 03:50:27.099 2483 2588 I BroadcastQueue: am_broadcast_enqueue: [foreground,1,Intent { act=android.intent.action.PACKAGE_NEEDS_VERIFICATION dat=file:///data/app/vmdl219912736.tmp typ=application/vnd.android.package-archive flg=0x10000011 cmp=com.android.vending/com.google.android.vending.verifier.PackageVerificationReceiver (has extras) },1]
05-15 03:50:27.103 5269 5269 I Finsky : [1] com.google.android.vending.verifier.PackageVerificationReceiver.onReceive(12): Verification requested, id = 2
05-15 03:50:27.110 2483 4727 I BroadcastQueue: am_broadcast_finished: [foreground,1,Intent { act=android.intent.action.PACKAGE_NEEDS_VERIFICATION dat=file:///data/app/vmdl219912736.tmp typ=application/vnd.android.package-archive flg=0x10000011 (has extras) }]
05-15 03:50:27.100 12138 12138 W qcom-system-dae: type=1400 audit(0.0:9187): avc: denied { read write } for name="diag" dev="tmpfs" ino=1995 scontext=u:r:qcomsysd:s0 tcontext=u:object_r:diag_device:s0 tclass=chr_file permissive=0 ppid=1 pcomm="init" pgid=1 pgcomm="init"
05-15 03:50:27.112 12138 12138 I libmdmdetect: ESOC framework not supported
05-15 03:50:27.113 12138 12138 I libmdmdetect: Found internal modem: modem
05-15 03:50:27.113 12138 12138 E QCOMSysDaemon: Can't find/open bootselect node: (No such file or directory)
05-15 03:50:27.113 12138 12138 I QCOMSysDaemon: Starting qcom system daemon
05-15 03:50:27.113 12138 12138 E Diag_Lib: Diag_LSM_Init: Failed to open handle to diag driver, error = 13
05-15 03:50:27.113 12138 12138 E QCOMSysDaemon: Diag_LSM_Init failed : 0
05-15 03:50:27.118 5269 12139 I Finsky : [324] com.google.android.vending.verifier.as.a(41): Skipping verification because own installation
05-15 03:50:27.119 5269 12139 I Finsky : [324] com.google.android.vending.verifier.as.a(58): Skipping anti malware verification due to pre-check failure
05-15 03:50:27.120 5269 5269 I Finsky : [1] com.google.android.vending.verifier.bk.c(91): Verifying id=2, result=1
05-15 03:50:27.122 2483 2588 I BroadcastQueue: am_broadcast_enqueue: [background,0,Intent { act=android.intent.action.PACKAGE_VERIFIED dat=file:///data/app/vmdl219912736.tmp typ=application/vnd.android.package-archive flg=0x11 (has extras) },1]
05-15 03:50:27.122 2483 2514 I BroadcastQueue: am_broadcast_finished: [background,0,Intent { act=android.intent.action.PACKAGE_VERIFIED dat=file:///data/app/vmdl219912736.tmp typ=application/vnd.android.package-archive flg=0x11 (has extras) }]
05-15 03:50:27.125 5269 5269 I Finsky : [1] com.google.android.vending.verifier.bk.c(102): Verification complete: id=2, package_name=com.facebook.katana
05-15 03:50:27.162 2483 2588 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.READ_CONTACTS in package: com.facebook.katana at: Binary XML file line #85
05-15 03:50:27.162 2483 2588 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.WRITE_CONTACTS in package: com.facebook.katana at: Binary XML file line #86
05-15 03:50:27.163 2483 2588 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.RECEIVE_BOOT_COMPLETED in package: com.facebook.katana at: Binary XML file line #161
05-15 03:50:27.163 2483 2588 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.BLUETOOTH in package: com.facebook.katana at: Binary XML file line #189
05-15 03:50:27.163 2483 2588 W PackageParser: Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.BLUETOOTH_ADMIN in package: com.facebook.katana at: Binary XML file line #190
05-15 03:50:27.196 2483 2588 W PackageManager: Package com.facebook.katana attempting to redeclare permission com.facebook.receiver.permission.ACCESS already owned by com.facebook.appmanager
05-15 03:50:27.256 728 728 E : Couldn't opendir /data/app/vmdl219912736.tmp: No such file or directory
05-15 03:50:27.256 2483 2588 I BroadcastQueue: am_broadcast_enqueue: [background,0,Intent { act=com.android.vending.INTENT_PACKAGE_INSTALL_COMMIT.com.facebook.katana flg=0x10 (has extras) },1]
05-15 03:50:27.257 2483 2514 I BroadcastQueue: am_broadcast_finished: [background,0,Intent { act=com.android.vending.INTENT_PACKAGE_INSTALL_COMMIT.com.facebook.katana flg=0x10 (has extras) }]
05-15 03:50:27.264 5269 5269 E Finsky : [1] com.google.android.finsky.installer.an.onReceive(22): Error -505 while installing com.facebook.katana: INSTALL_FAILED_DUPLICATE_PERMISSION: Package com.facebook.katana attempting to redeclare permission com.facebook.receiver.permission.ACCESS already owned by com.facebook.appmanager
05-15 03:50:27.265 2483 3543 I ActivityManager: Killing 5567:com.sonymobile.wifi:idd/1000 (adj 906): empty #17
05-15 03:50:27.288 2483 4727 D ActivityManager: cleanUpApplicationRecord -- 5567
05-15 03:50:27.293 5269 5269 W Finsky : [1] com.google.android.finsky.installer.a.t.a(20): Install failure of com.facebook.katana: -505 null
05-15 03:50:27.298 5269 5269 I Finsky : [1] com.google.android.finsky.installer.a.r.a(171): Cancel running installation of com.facebook.katana (com.facebook.katana)And here's my phone info
Re-read that log and figured that pesky com.facebook.appmanager could be coming from another Facebook app - Messenger. So I removed that and yay - Facebook installed. But now Messenger is the one getting -505.
I wonder if this is Z5 specific.
Edit: aaand I somehow missed an existing topic about this and now I feel like an idiot. Still, there is still no proper solution for this as far as I understand.
For everything is running well Facebook and Messenger
I posted it and you are looking for anything else
Do a factory reset and you'll be over of this issue
Otherwise you'll wait for an update from Sony which is not planned for tomorrow
