Hi guys
I found the solution, everything works fine now
First make a factory reset
When it's done do not install or update any thing
Open Google play store (don't apply any update)
Search and install Messenger it will pass
Then update Facebook it will pass too
Then you can install and update whatever you want
Enjoy
-505 always in Google. Sony and google says its facebooks problem... No help there..Facebooks never Answer ....
How to correct this install error
Thanks
Downloading Facebook fail and messege error 505 appear, how to solve that problem
Thanks for your reply
Already done but issue is remaining
The matter is in install process which fails
I tried also to install from apk file and got the same error
Hi,
Messenger software stopped working after the update of Android 7.0. Tried to install the software all over again but this time i receive error -505.
I have followed every step to locate the error but nothing helped me to solve the problem.
I have compact Xperia, software 7.0 installed
