3 Weeks Later I Get My Laptop Bq From Sony With Minor Problem...
a7med_360
Visitor
Hey, i received my laptop today, after 3weeks of being repaired well mainly just changing the keyboard :thinking: .............but not the volume key and keys surrounding it are not working mute key and eject key.....neither does the camera, i downloaded the vaio camera capture program but it says no input even tho it display my camera in the settings..also when im using msn/wlm now i put the font size to 8 however it doesnt stay when i open another convo it will go bq to size 10......vaio ar21s+vista....plzz help tnxx
23 REPLIES 23
a7med_360
Visitor
the drive works i ripped afew cd's yesterday its only the buttons on the left hand side of the keyboard that are not working........S1 S2 volume mute & eject
rich912
Contributor
Hi a7med_360,
To restore the function of the volume buttons try downloading the following Sony Vista Utilities from here
1 Sony Utils
1 Sony Shared Library
3 Vaio Event Service
…and then install in that order followed by a re-boot. If this doesn’t work the first time around then try at least a couple of times more.
Hopefully this will cure the problem.
Go n-éirí an bóthar leat
a7med_360
Visitor
I tried these three in this order installed them around 3-4x and they didnt work
Sony Utils DLL 7.0.00.11210 2 MB 21/02/2007
Sony Shared Library 3.0.00.10180 2.53 MB 22/02/2007
Sony Video Shared Library 3.1.00.10240 3.69 MB 22/02/2007
y2krog2000
Visitor
as windows vista has bugs and a virus init that stops things from working
most people who have vista have the problem of some keys not working
and camara not working
Now thats just a load of b*ll*cks, why do you lie?
rich912
Contributor
In that case, unless anyone else has further ideas, we are back to the factory restore. Make sure you backup your data first….
rich912
Contributor
I couldn't agree more y2krog2000 :slight_frown:
a7med_360
Visitor
it wouldnt make a difference if i did a factory restore because as u say if these 3 steps are what installs the connection for the buttons the factory restore will do the same!.........maybe sony may have disconnected a few wires during repair of the laptop???
Thalamus.
Champion
Hi a7med_360,
Before jumping to conclusions try, as Rich912 stated, a factory restore and restore your Vaio back to the factory settings, if the function of the volume buttons still do not work correctly then you can contact vaio link again.. :wink:
a7med_360
Visitor
restoring to factory setting means that i would have to re-install vista??? plus at the moment i dnt have any medium to back up my dad except the partition hard drive built in
profile.country.en_GB.title
kee-lo_
Member
This is the only way out from what I can see, if you can get some DVD-RWs then it won't be so much hassle.
