Reject with a message
ssd
Visitor
whenever i reject a call a message gets sen t viz. im busy  will call u back later., which is ending my balance.. now how to disable the "Reject Call With A Message" ???
61 REPLIES 61
Omerinine
Visitor
Alexander
Sony Xperia Support
Re: Reject with a message
Friday
If you disable the messaging app under settings > apps > all > messaging > disable and instead downloading a 3rd party messaging app from Google Play, the 'reject call with a message' function should disappear. It should only be supported by the original messaging app. ./
Hi sony. Could you just acknowledge the mistake in design and correct it by a software upgrade? If you disable the default messaging, it will still cut the call at the other end as user busy when reject call with message sends due to friction in your pocket.the only thing your balance won't be affected.imagine,sending your boss a message you are busy or caller busy appearing in his phone screen when he calls to enquire about an assignment assigned to you?
doucmeasicu
Visitor
Disabling messages didn't work for me - got another message app but still get the disable with message option and it works as usual - I'm losing work because of this frustrating feature - Sony is losing customers - Xperia worst phone I've ever owned
discretion1
Contributor
I had this problem on my Xperia E, and two days after I bought the phone, I installed a call confirm app from play store.
https://play.google.com/store/apps/details?id=com.perracolabs.tcc&hl=en
I disabled the app for outgoing calls and activated it only for incoming calls. The app makes the incoming call screen responsive to touch only after you get through the app's own lock interface, but gives you a transparent view of the incoming call screen. So far the app has been okay to me, but you can also try a few other apps if you like.
Nidhin
Visitor
Nidhin
Visitor
ninu
Visitor
me too want to know how to do that
Tags (1)
Housam77
Visitor
If you disable the messaging app under settings > apps > all > messaging > disable and instead downloading a 3rd party messaging app from Google Play, the 'reject call with a message' function should disappear. It should only be supported by the original messaging app. ./ I do it that but i lost this option in my phone i want re messaging I was trieng to Enabled the messaging from settings > apps > all > messaging but I dont find this item ........please help .. thanks
Tags (1)
ewoutli
Visitor
hi,
i want to know how i must make a screenshot with the Sony Xperia E.
does anybody know it?
thank you.
discretion1
Contributor
Press and hold volume-down and power buttons at the same time.
http://www.sonymobile.com/in/support/faq/xperia-p/system/how-do-i-make-a-screenshot-1/
You may start a new discussion by posting a new message, and before that you may want to check other existing threads for an answer to your question.
http://talk.sonymobile.com/t5/Xperia-Z-ZL-ZR/Screen-shot-on-Xperia-Z-after-4-2-2-update/td-p/337696
ewoutli
Visitor
thank you now i try of it works!!!!
