Reject with a message
ssd
Visitor
whenever i reject a call a message gets sen t viz. im busy  will call u back later., which is ending my balance.. now how to disable the "Reject Call With A Message" ???
61 REPLIES 61
ssd
Visitor
But by range and economic view for youngsters they rock.
Maelstrom1
Visitor
Johan wrote:
Please share the info over PM (Personal Message) so it won't be out in the open.
I need this info to be able to verify/replicate the problem and to escalate it to concerned project.
Phone number is not really needed.
Forget it.
I will not share information just because your QA guys are lazy or can't test this for themselves.
For Heaven's sake, you're Sony, you have the power, so use it.
Besides, you can replicate the "problem" without my information. It's a missing feature which was also reported on Xperia Tipo.
So be pros and stop giving me the runaround!
midhuns3343
Visitor
Same thing happens to me often... it simply takes all my balance Slightly_frowning_Face
ninomrki
Visitor
Go to call settings and change all the messages to be blank. It will still show the option and reject calls, but it should stop the phone from sending messages. It worked for me.
grg
Visitor
I have a z ultra and am having the same problem. is there a way or app or anything to disable this feature?
grg
Visitor
it didn't work, when the message is blank, am not able to save it.
joseferreira77
Visitor
johan i'll send you some of my info. you can call me to discuss this.
i am with maelstrom on this same problem. quite a clever device sony put in on the answer screen, but it is unfortunately poorly implemented and more of a design flaw.
KYONG
Visitor
I hate this function so much. Sometimes I accidently touch my phone when grabbing a phone call, this function reject my call with reject message.
This happen very quickly and sometimes is not noticeable.
Further more, due to this function. Phone, Xperia S hangs when answering call.
Please disabled or removed this function.
Let me know the app's name, so that I can disabled it immediately.
FYI, I am using Xperia S
Alexander1
Champion
If you disable the messaging app under settings > apps > all > messaging > disable and instead downloading a 3rd party messaging app from Google Play,  the 'reject call with a message' function should disappear. It should only be supported by the original messaging app.
Omerinine
Visitor
When I tried it, it did not stop the message from sending and appearing as busy on the caller's phone. Sony, imagine sending your boss a busy message accidentally.
