Reject with a message
ssd
Visitor
whenever i reject a call a message gets sen t viz. im busy  will call u back later., which is ending my balance.. now how to disable the "Reject Call With A Message" ???
61 REPLIES 61
ssd
Visitor
what if i dont want to send a message while rejecting a call?? if its a prank and i reject it  a message gets sent and my balance goes .. please make a new feature of disabling "REPLY WITH A MESSAGE" service..
Uliwooly
I don't understand, you can just ignore the call so that it will go to your voicemail?
my understanding on "reject call with message" was that if someone call you, you have to drag up the message options and the message will be sent, if you dont then nothing should be sent, is the Xperia E different?
ssd
Visitor
Please enable such features in your new updates . this will make XPERIA a phone with best UI
Uliwooly
@ssd can you elaborate?
ssd
Visitor
How to disable that feature ?? whenever i reject a call (either by dragging red icon or pressing a power button) a message automatically gets sent to the caller even if i dont want to. how to disable REPLY WITH MESSSAGE  service
Uliwooly
now that's odd, with my Xperias you have to select the sms if you want it to be sent, it doesn't send anything automatically, if I don't answer or swipe the red bar, the call will be sent to voice mail not sms. I wonder if this is a network feature, is your phone network branded?
ssd
Visitor
Vodafone In.
Uliwooly
now I'm quite interested on this, if this is a Sony setting or if it was implemented by Vodafone India. like I said, with my other Xperias you have to select the reject with message message, it wont send anything otherwise, contact Vodafone and see what they have to say about this
ssd
Visitor
those vodafone people are of no use . i went there with my network problem with play store they are sayin its because playstore doesnt support 2G so you haave to upgrade to 3G . really waiting for my sim to get 3 months old and im porting it to another service provider
Uliwooly
their answer doesn't make any sense at all, wow, they are special Dizzy_Face
