TV BRAVIA - Aggiornamento del firmware alla versione 6.6555
https://www.sony.it/electronics/support/lcd-tvs-android-xf90xx_x90xxf-series/kd-49xf9005/downloads/0...
Vantaggi e miglioramenti dall'aggiornamento precedente
  • Migliora la reattività del TV all'accensione dalla modalità standby
Modelli applicabili
Queste informazioni sono valide per i seguenti modelli di TV:
  • KD-43XG8305
  • KD-49XG8305
  • KD-49XG8377
  • KD-43XG8388
  • KD-49XG8388
  • KD-43XG8396
  • KD-49XG8396
  • KD-43XG8399
  • KD-49XG8399
  • KD-49XG9005
  • KD-55AG8
  • KD-65AG8
  • KD-43XG8096
  • KD-49XG8096
  • KD-55XG8096
  • KD-65XG8096
  • KD-75XG8096
  • KD-43XG8196
  • KD-49XG8196
  • KD-55XG8196
  • KD-65XG8196
  • KD-65AF8
  • KD-55AF8
  • KD-75XF9005
  • KD-65XF9005
  • KD-55XF9005
  • KD-49XF9005
  • KD-65XF8796
  • KD-55XF8796
  • KD-49XF8796
  • KD-43XF8796
  • KD-65XF8599
  • KD-55XF8599
  • KD-49XF8599
  • KD-43XF8599
  • KD-85XF8596
  • KD-75XF8596
  • KD-65XF8596
  • KD-55XF8596
  • KD-49XF8596
  • KD-43XF8596
  • KD-65XF8588
  • KD-55XF8588
  • KD-49XF8588
  • KD-43XF8588
  • KD-65XF8577
  • KD-55XF8577
  • KD-49XF8577
  • KD-43XF8577
  • KD-65XF8505
  • KD-55XF8505
  • KD-49XF8505
  • KD-43XF8505
  • KD-70XF8305
  • KD-60XF8305
  • KD-55XF8096
  • KD-49XF8096
  • KD-43XF8096
  • KD-65XF7596
  • KD-55XF7596
  • KD-49XF7596
  • KD-43XF7596
  • KDL-49WF805
  • KDL-43WF805
  • KDL-49WF804
  • KDL-43WF804
  • KD-77A1
  • KD-65A1
  • KD-55A1
  • KD-75XE9405
  • KD-65XE9305
  • KD-55XE9305
  • KD-75XE9005
  • KD-65XE9005
  • KD-55XE9005
  • KD-49XE9005
  • KD-75XE8596
  • KD-65XE8599
  • KD-65XE8596
  • KD-65XE8588
  • KD-65XE8577
  • KD-65XE8505
  • KD-55XE8599
  • KD-55XE8596
  • KD-55XE8588
  • KD-55XE8577
  • KD-55XE8505
  • KD-55XE8396
  • KD-55XE8096
  • KD-49XE8396
  • KD-49XE8099
  • KD-49XE8096
  • KD-49XE8088
  • KD-49XE8077
  • KD-49XE8005
  • KD-49XE8004
  • KD-43XE8396
  • KD-43XE8099
  • KD-43XE8096
  • KD-43XE8077
  • KD-43XE8005
  • KD-43XE8004
  • KD-100ZD9
  • KD-75ZD9
  • KD-65ZD9
  • KD-49XD8305
  • KD-43XD8305
  • KD-55XD8005
  • KD-49XD8005
  • KD-43XD8005
  • KD-49XD8077
  • KD-43XD8077
  • KD-49XD8088
  • KD-43XD8088
  • KD-49XD8099
  • KD-43XD8099
  • KD-65XD7504
  • KD-65XD7505
  • KD-55XD7004
  • KD-49XD7004
  • KD-55XD7005
  • KD-49XD7005
  • KD-50SD8005
168 RISPOSTE 168
phoenix03
Non ho notato cambiamenti, a parte la patch di sicurezza Android che è stata aggiornata a Gennaio 2020. Credo sia un aggiornamento poco rilevante, ma è sempre meglio avere l'ultima versione.
Bruxk120
Io ho aggiornato con pennetta quasi subito e quindi sono ormai diversi giorni che sto osservando il comportamento del televisore.
In effetti, sicuramente, non ci sono cambiamenti di rilievo a parte la "sicurezza" ma in ogni caso almeno per me ho notato un miglioramento nella stabilità della connessione wifi.
Prima dell'aggiornamento, specialmente dopo lunghi periodi di stand-by, quando riaccendevo il televisore capitava non proprio raramente che la connessione wifi non venisse riattivata e in certi casi sono stato costretto a riavviare il dispositivo.
Ora non capita più!
Ribadisco, però, che altri miglioramenti significativi non ne ho notati.
Saluti
phoenix03
Ah quello non saprei, perchè io a internet l'ho collegata col cavo Ethernet.
fungoa
Risolto da Mac con un’altra usb stick formattata fat32; MBR, da utility disco. Ho decompresso Il file .zip con il Finder e inserita la chiavetta l’ha letta immediatamente. Va a capire. Grazie!
dannix
ottimo l'importante è risolvere i problemi....
dadaumpa87
Arrivato aggiornamento OTA. Dopo una settimana ho iniziato ad avere problemi con il WiFi (Netflix funzionava ma il resto no). Neanche con cavo ethernet.
Fatto reset di fabbrica e ora va solo con ethernet. Google home non accetta più nessun comando (accendi/spegni/avviare video su YouTube). Per me grande peggioramento. Se provo a connettermi in wifi anche se la password è corretta non si connette, provato anche con hotspot..
Suggerimenti?
Salve @dadaumpa87 , ti consiglio di rifare ancora un ripristino a dati di fabbrica ma questa volta scollegando tutto e lasciando solo il cavo di alimentazione. Poi durante il wizard iniziale ricollega ciò che ti chiede la tv. Inoltre ti consiglio di effettuare il ripristino con i tasti posteriori della tv. Ti metto una guida per questo.
https://www.sony.it/electronics/support/televisions-projectors-oled-tvs-android-/kd-55a1/articles/00...
mucchio84
Perché dall'ultimo aggiornamento il mio KD-43XF7096 non funziona più il tasto home e tasto you tube?!
Fai il riavvio della tv (stacca la spina per qualche minuto) oppure se non va fai il ripristino ai dati di fabbrica. Naturalmente dovrai reinserire tutto e rifare la scansione dei canali.
