TV BRAVIA - Aggiornamento del firmware alla versione 6.6555
https://www.sony.it/electronics/support/lcd-tvs-android-xf90xx_x90xxf-series/kd-49xf9005/downloads/0...
Vantaggi e miglioramenti dall'aggiornamento precedente
  • Migliora la reattività del TV all'accensione dalla modalità standby
Modelli applicabili
Queste informazioni sono valide per i seguenti modelli di TV:
  • KD-43XG8305
  • KD-49XG8305
  • KD-49XG8377
  • KD-43XG8388
  • KD-49XG8388
  • KD-43XG8396
  • KD-49XG8396
  • KD-43XG8399
  • KD-49XG8399
  • KD-49XG9005
  • KD-55AG8
  • KD-65AG8
  • KD-43XG8096
  • KD-49XG8096
  • KD-55XG8096
  • KD-65XG8096
  • KD-75XG8096
  • KD-43XG8196
  • KD-49XG8196
  • KD-55XG8196
  • KD-65XG8196
  • KD-65AF8
  • KD-55AF8
  • KD-75XF9005
  • KD-65XF9005
  • KD-55XF9005
  • KD-49XF9005
  • KD-65XF8796
  • KD-55XF8796
  • KD-49XF8796
  • KD-43XF8796
  • KD-65XF8599
  • KD-55XF8599
  • KD-49XF8599
  • KD-43XF8599
  • KD-85XF8596
  • KD-75XF8596
  • KD-65XF8596
  • KD-55XF8596
  • KD-49XF8596
  • KD-43XF8596
  • KD-65XF8588
  • KD-55XF8588
  • KD-49XF8588
  • KD-43XF8588
  • KD-65XF8577
  • KD-55XF8577
  • KD-49XF8577
  • KD-43XF8577
  • KD-65XF8505
  • KD-55XF8505
  • KD-49XF8505
  • KD-43XF8505
  • KD-70XF8305
  • KD-60XF8305
  • KD-55XF8096
  • KD-49XF8096
  • KD-43XF8096
  • KD-65XF7596
  • KD-55XF7596
  • KD-49XF7596
  • KD-43XF7596
  • KDL-49WF805
  • KDL-43WF805
  • KDL-49WF804
  • KDL-43WF804
  • KD-77A1
  • KD-65A1
  • KD-55A1
  • KD-75XE9405
  • KD-65XE9305
  • KD-55XE9305
  • KD-75XE9005
  • KD-65XE9005
  • KD-55XE9005
  • KD-49XE9005
  • KD-75XE8596
  • KD-65XE8599
  • KD-65XE8596
  • KD-65XE8588
  • KD-65XE8577
  • KD-65XE8505
  • KD-55XE8599
  • KD-55XE8596
  • KD-55XE8588
  • KD-55XE8577
  • KD-55XE8505
  • KD-55XE8396
  • KD-55XE8096
  • KD-49XE8396
  • KD-49XE8099
  • KD-49XE8096
  • KD-49XE8088
  • KD-49XE8077
  • KD-49XE8005
  • KD-49XE8004
  • KD-43XE8396
  • KD-43XE8099
  • KD-43XE8096
  • KD-43XE8077
  • KD-43XE8005
  • KD-43XE8004
  • KD-100ZD9
  • KD-75ZD9
  • KD-65ZD9
  • KD-49XD8305
  • KD-43XD8305
  • KD-55XD8005
  • KD-49XD8005
  • KD-43XD8005
  • KD-49XD8077
  • KD-43XD8077
  • KD-49XD8088
  • KD-43XD8088
  • KD-49XD8099
  • KD-43XD8099
  • KD-65XD7504
  • KD-65XD7505
  • KD-55XD7004
  • KD-49XD7004
  • KD-55XD7005
  • KD-49XD7005
  • KD-50SD8005
168 RISPOSTE 168
Ok, ma se vuoi riprovare usa WinRAR.
roravag
Tramite OTA ancora nulla giusto?
No a quanto pare.
divitarosario
Stesso problema dimensione file scaricato:  1.886.030.134 byte,  inferiore alle dimensioni del file originale 1 886 350 011 byte,  non funziona si blocca l' aggiornamento.
Ma il peso del File è da decompresso?
divitarosario
si
Appena provato, mi rispondo da solo, hai verificato il peso del File decompresso.
Quindi il File scaricato è corretto, il problema deve essere altrove, cambia USB o decomprimi con WinRAR (se hai usato altro o se si è decompresso automaticamente) e verifica che la Tabella delle Partizioni della USB sia di tipo MBR.
divitarosario
Grazie dei consigli.
divitarosario
Risolto con il tuo consiglio, sostituita chiavetta  USB  aggiornamento fatto.
