Bluetooth does NOT work
SOLVED
JakobA
Visitor
Bluetooth om my Xperia arc S (LT18i) with android 4.0.4 (4.1.B.0.587) does not work. It cannot find my bluetooth headset or my laptop.
I have search the internet for a solution but can't find any.
1 ACCEPTED SOLUTION
Accepted Solutions
ArcSBlack
Visitor
9 REPLIES 9
ArcSBlack
Visitor
No offence, man, but if you bought A SINGLE CORE CPU Android in 2012, you're the big......
JakobA
Visitor
and a dual/quad would solve the problem?
ArcSBlack
Visitor
Of course not, man..(I meant smth else by that). What OS do you have on your laptop?
JakobA
Visitor
Win7 64
ArcSBlack
Visitor
Control panel>> Devices and printers>> Add a device. Make sure you have bluetooth on and it is discoverable for all devices for an  unlimited period of time so you don't have any probems from that part...
1) When you try to discover the device Lt18i, can your laptop see it? Can you pair it?
ArcSBlack
Visitor
JakobA
Visitor
Okay... now you're talking 🙂
First part of the problem now is solved. I have paired the phone and my laptop and transferred a photo. It works... thank you very much so far.
But the phone can still not find my GoGroove bluetooth headset. Any suggestions?
ArcSBlack
Visitor
I do not know about that one.... What I could help you out with I did:)
Don't forget :
  • Correct Answers - 30 points
  • Helpful Answers - 10 points
JakobA
Visitor
Oops... and now I found the answers at gogrooveaudio.com 🙂
Thanks
