Bluetooth om my Xperia arc S (LT18i) with android 4.0.4 (4.1.B.0.587) does not work. It cannot find my bluetooth headset or my laptop.
I have search the internet for a solution but can't find any.
Solved! Go to Solution.
No offence, man, but if you bought A SINGLE CORE CPU Android in 2012, you're the big......
and a dual/quad would solve the problem?
Of course not, man..(I meant smth else by that). What OS do you have on your laptop?
Win7 64
Control panel>> Devices and printers>> Add a device. Make sure you have bluetooth on and it is discoverable for all devices for an unlimited period of time so you don't have any probems from that part...
1) When you try to discover the device Lt18i, can your laptop see it? Can you pair it?
Okay... now you're talking 🙂
First part of the problem now is solved. I have paired the phone and my laptop and transferred a photo. It works... thank you very much so far.
But the phone can still not find my GoGroove bluetooth headset. Any suggestions?
I do not know about that one.... What I could help you out with I did:)
Don't forget :
Oops... and now I found the answers at gogrooveaudio.com 🙂
Thanks
