Hi guys I'm using the sony Zh8 8k tv and I can't seem to be able to mirror from my phone to the tv anymore. when I 1st got the tv it worked fine even on YouTube videos. I'm using the Samsung galaxy S10 .but I think o could have stop connecting after a software update on the tv . when I open the smart view option on my phone its not picking up the sony. funny enough I can pick up the neighbours lg tv but not mine. any advice is more than welcome and thanks again for everyone's help. cheers
I cant ChromeCast to my tv anymore either after the latest update
@Deckstar . cheers for your reply the tv is the sony KD75ZH8BU 8K TV
the only thing I can find in the settings is kernel version
4.9.125 #1 wed Feb 3
that seems to be the only thing that relates to the time of the last upgrade . Thanks again for your help
The latest software version for your TV is v6.5042, try updating to it and see if that solves it for you.
funny enough I just tried a software update at 6pm this evening and it stated I have the latest update. thanks again for your help
I had same issue recently. When I checked my network settings, it was saying my ethernet wasn't connected, despite all apps working. I reset complete TV through the TV menu, not on/off button, it's a pain as you need to setup whole TV again, however, now shows ethernet connected and mirroring is working again
cheers pal I'll look into it. never thought about the network. hopefully this is the problem.
Thanks again
No problem bud, good luck
