z3 actual call volume after lollipop upgrade.
doom2
Visitor
since my phone upgraded to lollipop the other day my phone speakers actual call volume is so quiet I can't hear anybody, making my phone uaeless to receive calls, yes the side volume is on full . Yet if I play an Mp3 its as loud ad it use to be via kitkat, notifications are ok too as well as the ringtone. Its just the actual call volume which isnow useless unless you're in a month sound proof room.
Anyone know how to fix or if I can roll back to kitkat.
Cheers
D2
Tags (1)
99 REPLIES 99
drhany
Visitor
there is settings and about phone and i dont find diagnostics
drhany
Visitor
3 months ago and no solution for that problem from sony experia.phone with 800 $cannot make even calls
i need to get the first version of lollilop at least now
how can i get this?
titijuli
Visitor
Yesterday I updated my Xperia Z3 dual to the last firm (5.1.1) and the problem still. I  can't barelly hear the one who calls me.
Almost a year with it and lots of problems. Will Sony solve it somehow someday??? do i have to sell this phone??
MdAshiff
Visitor
Hey! I'm having Xperia Z3, I have an issue in top speaker suddenly the volume has gone down..please help me to fix this issue...
Uliwooly
@drhany
You should be able to see it, under about phone.
also, you can contact your local Xperia care
http://support.sonymobile.com/global-en/contactUs/
drhany
Visitor
the only beneficial solution till our weak sony experia find another solution is to format the phone and every thing is ok
Kltodo
Visitor
Hello Richard,
Many thanks for your reply I looked for the mentioned folder "etc" and I didn't find it.
Would be possible to have an update about this issue?
Would be possible to avoid the total reset of the telephone and have a fix instead. Expecially because this has effected all the Sony Z3 owners.
All of us look forward for your reply.
Best Regards,
Claudio
sparky1
Visitor
Return phone for a repair.
DieterVDW
Visitor
This update is ridiculous. Issues I'm having right now:
- Low earpiece volume
- Wifi doesn't connect
- Battery drains like crazy
- Weird play services issues
If possible I'm reverting. This update turned a great phone into a piece of **bleep**.
sparky1
Visitor
I recently had a big issue with the battery draining quickly.  I have had the phone for 6 months and it had been great.  It turned out that my exchange account was going wild resulting in the phone constantly being active despite it being locked in my pocket.  I turned off the sync for a few days and then restarted it and the battery was then lasting ok again.
I can't say that I've had much wifi issues here.  I moved my bt home hub as I had the odd moment where the internet would hang, I believed that was why I had issues with the google play services.  I occasionally do still get the odd error on the screen saying that "google play services has stopped" but it doesnt seem to affect anything other than just be annoying.
As for the low ear speaker volume, as mentioned before, mine was repaired under warranty and a new ear speaker installed, this resolved that issue.
Unfortunately my latest problem is that while on holiday the Z3 decided to not be as waterproof as it should be depsite the doors being closed......
