I also have issue with my Sony Z3 compact earpiece volume being too low after a recent update, even though its on maximum level setting. This is in addition to vibration no longer working (but thats a separate issue and another that others have reported).
I tried asking the staff in the local Sony shop but they didn't want to know.
Disable, reboot, enable of Audio Settings didn't work.
Safe mode had the same issue, so no change there.
Sony - please listen and put the mixer fix in so we don't have to root the phone!
Any update on this issue? This is completely insane, to use a Smart"Phone" which can't be used to attend calls.
Sony, you just messed up the basic thing in a Mobile Phone.
Hello,
I have xperia z3 running marshmallow , when i did the update to marshmallow i encountered the same problem i.e. the earpiece noise (volume) was considerably lower and when olaying mp3's or videos's the volume on the bottom speaker was higher than the top one .Ii had contacted sony customer care they suggested that i had a hardware problem but as i did my research on the internet i came accross sony customers with the same problem but they were running different versons of Android. I definitely think the problem is in the software though some might say otherwise. I have not come accross any fix for this particular issue , but if you may come across any solution or a fix , could you email me
I am having the same problem since the new 6 version update. People say I sound like I'm far away in a room when I call, I've tested it with my wifes phone and you can BARLEY hear me through the Z3 Compact, speakerphone works fine. I've disabled every option I can think off including google voice search etc and it still doesn't work. I'm super upset as I use the phone for my remote support job all the time, I'm working on downgrading to the previous version as soon as I can to get this thing working again. I almost always avoid updates and this time I thought, maybe....turns out I was wrong! I've found no solutions anywhere on the internet, probably as the update just came out.
HI. My z3 ring tone volume is very low even when my mobile is beside me I don't hear it. Any help please
@sparky1 wrote:
Oh and I have also used
@sparky1 wrote:
Oh and I have also used pc companion to erase and reinstall the phone incase the lollipop update had caused issues by overlaying over the top of kit kat when it rolled out.
I just updated the phone again and everything became normal
я просто обновил телефон еще раз и все стало нормально
