Hello,
today I was reseting my Xperia Z and as I want to add my Wifi, the Wifi want turn on so I reset my phone another time and the same problem returns! I don't no what to do now can anyone help me?
KiliYT
Solved! Go to Solution.
I fixt it!
I flashed the newest version and know everything is working!
Thank you for your help!
Sorry but there isn't help for my problem because I can't turn the W-Lan on and my Xperia Z is vibrating all the time I can't stop this!
Reseting my phone doesnt help I have done it 3 times today.
What if you boot on safemode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
It doesn't worked. Nothing changed. ;(
When I plug it in to the PC Sony PC Companion says there is a new software available but when I want to install it, it tells my mistake 10 is happend. So I can not install the newest software. D;
I'm glad I was able to help
i have sony xperia zr. unable to connect wifi. this is because of kitkat 4.4.4.
please help regarding my phone's issure.
