Solved! Go to Solution.
Cheers
Do you have adaptive brightness enabled? Try to clean the sensor as it is very sensitive.
The sensor might not work properly if there is grease or dirt on it. It is located in the upper right part of the screen, near the notification light:
http://support.sonymobile.com/gb/xperiaz5compact/userguide/Overview-SN/
Cheers
