Sony Xperia Z1 battery Problem
Dostum
Visitor
Hello Guys:
I have problem with my Sony Xperia Z1 mobile.
Can anyone explain why this is happening?
My battery drained from more then 90% to 15% immideately in 2~3 min. But funny thing is, when I recharge, it is back to around 80% very quickly again in few minutes...
I have this problem, and I tried to factory set my mobile, everything work normal again. But unfortunately when I Restore my backup file earlier, Battery problem suddenly happen again.
My question is, Is there any bug in Sony operating system?
The reason why i am telling this because I don't think this is my mobile battery problem, must be some kind of setting modified my battery life when i did restore.
I hope Sony solve this problem ASAP...
Thank you!
Tags (3)
4 REPLIES 4
Jake-SonyXperia
Champion
Hi Dostum,
Welcome to the community,
This sounds like you have a problem with the content on the backed up file.
I could only really suggest that you try a reset again and only import specific data, such as messages, call logs and media, however system data should be not be moved across.
Give that a go and see if the issue continues, and let us know.
Dostum
Visitor
Thank you Jake:
I did a clean factory reset my phone by following your instruction.
Unfortunately, I still getting sudden drain on my battery.
Most recent one was last night, it was automatically turned off when battery shows around 45%.
I wish you could help...
Thank you!
Uliwooly
sijo
Visitor
I am experiencing same issue....please help me.Is it a software issue
