Z3 Battery Problems
AbiChristo16
Visitor
Z3 Battery Problems
I have problems with my phones battery life. I have taken all the steps that they advice you to do to stop your battery from draining, but so far nothing has changed. It worked exceptionally until now. Is there anyone who has experience the same issue? What can be done more?
Tags (3)
6 REPLIES 6
Hampus
Champion
Hi,
Have you checked via Settings > Power management > Battery usage to see if you can find something abnormal here? I suggest that you check this list when you have around 5-10% battery left since it will show the consumption since last charge. You could also post a screenshot and we can look closer into it.
KevinHancock
Visitor
I have the same problem with M2. Google Play services app is using 79%.....
Uliwooly
@KevinHancock @AbiChristo16
I've seen this behaviour before on a Z3
settings > apps > all > look for all Google services and apps > uninstall updates and clear data on all them > restart the phone > charge your phone > check again for a day or two.
Also check if you are autobacking with Google + / photos
KevinHancock
Visitor
Cheers pal!! Just 19% battery used in 24 hours. Things are looking up:smileyhappy:
Uliwooly
@KevinHancock
Excellent, keep us updated.
ÁlvaroAlchaar
Visitor
how you did it clearly explains please i am brazilian and I do not know much english
