my Xperia is not detecting sony head phone. when i reboot my phone with headset , i am able to hear in head set and not through loud speaker. when i reboot phone without headset , i am able to hear in loudspeaker and not through head set. please help.
please reply with solid solution not like that update phone soft , clear slot etc .
Settings-apps-all-smart connect,force stop and clear data.Restart your phone.
If that doesn't help, try connect another headset to see if you experience the same behavior.
hello Sir ,
THis is not an Harware issue , it is issue in software , the problem persist with this solution .
it is solved when i install thir party app sound baout can you please tell me the solution how can i solve this problem .
I have an issue with headphone insertion event
its not showing the icon of inseerion and some time in ear call volume problem .
Use my above suggestion.You could also boot your phone into safe mode and see how it goes:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
hello Sir i have applied solution that you provided above but didn't succeded ...........
PLease suggest other solution thanks in advance .
I can see,try and download sony update service to repair your device:
http://www.sonymobile.com/gb/tools/update-service/
Hi, I have a same problem, bt it's solved now.
Do following steps,
1- clean your 3.5mm jack using cotton and just 1 or 2 drops of spirit, now again clean it with new cotton without spirit.
2- now update your smart connect sotware, and select select handst option>music on to go> on.
now, your handsfree will be surely detected.
i've found a different solution:
go to the sound settings and enable xloud enhancement, this did the trick for me.
i did this after the previous steps of clearing the data for the smart connect app and cleaning the headphone jack,
so you might wanna try this too.
I had the same problem and came to this discussion. As people suggested to clean the headphone jack.
I did and it worked.
I switched off my phone. I took ear stick and I drenched it in water and squeezed it. I removed some cotton to insert the stick easily and rotated it some times. The jack got cleaned and it was shining. I left it for sometime to dry. I rebooted the phone and checked it with earphone and it is working as it should. Whenever I plugin earphone music starts automatically and when I plugout it, music stops.
Thanks guys for the solution.
