TV BRAVIA - Aggiornamento del firmware alla versione 6.6555
https://www.sony.it/electronics/support/lcd-tvs-android-xf90xx_x90xxf-series/kd-49xf9005/downloads/0...
Vantaggi e miglioramenti dall'aggiornamento precedente
  • Migliora la reattività del TV all'accensione dalla modalità standby
Modelli applicabili
Queste informazioni sono valide per i seguenti modelli di TV:
  • KD-43XG8305
  • KD-49XG8305
  • KD-49XG8377
  • KD-43XG8388
  • KD-49XG8388
  • KD-43XG8396
  • KD-49XG8396
  • KD-43XG8399
  • KD-49XG8399
  • KD-49XG9005
  • KD-55AG8
  • KD-65AG8
  • KD-43XG8096
  • KD-49XG8096
  • KD-55XG8096
  • KD-65XG8096
  • KD-75XG8096
  • KD-43XG8196
  • KD-49XG8196
  • KD-55XG8196
  • KD-65XG8196
  • KD-65AF8
  • KD-55AF8
  • KD-75XF9005
  • KD-65XF9005
  • KD-55XF9005
  • KD-49XF9005
  • KD-65XF8796
  • KD-55XF8796
  • KD-49XF8796
  • KD-43XF8796
  • KD-65XF8599
  • KD-55XF8599
  • KD-49XF8599
  • KD-43XF8599
  • KD-85XF8596
  • KD-75XF8596
  • KD-65XF8596
  • KD-55XF8596
  • KD-49XF8596
  • KD-43XF8596
  • KD-65XF8588
  • KD-55XF8588
  • KD-49XF8588
  • KD-43XF8588
  • KD-65XF8577
  • KD-55XF8577
  • KD-49XF8577
  • KD-43XF8577
  • KD-65XF8505
  • KD-55XF8505
  • KD-49XF8505
  • KD-43XF8505
  • KD-70XF8305
  • KD-60XF8305
  • KD-55XF8096
  • KD-49XF8096
  • KD-43XF8096
  • KD-65XF7596
  • KD-55XF7596
  • KD-49XF7596
  • KD-43XF7596
  • KDL-49WF805
  • KDL-43WF805
  • KDL-49WF804
  • KDL-43WF804
  • KD-77A1
  • KD-65A1
  • KD-55A1
  • KD-75XE9405
  • KD-65XE9305
  • KD-55XE9305
  • KD-75XE9005
  • KD-65XE9005
  • KD-55XE9005
  • KD-49XE9005
  • KD-75XE8596
  • KD-65XE8599
  • KD-65XE8596
  • KD-65XE8588
  • KD-65XE8577
  • KD-65XE8505
  • KD-55XE8599
  • KD-55XE8596
  • KD-55XE8588
  • KD-55XE8577
  • KD-55XE8505
  • KD-55XE8396
  • KD-55XE8096
  • KD-49XE8396
  • KD-49XE8099
  • KD-49XE8096
  • KD-49XE8088
  • KD-49XE8077
  • KD-49XE8005
  • KD-49XE8004
  • KD-43XE8396
  • KD-43XE8099
  • KD-43XE8096
  • KD-43XE8077
  • KD-43XE8005
  • KD-43XE8004
  • KD-100ZD9
  • KD-75ZD9
  • KD-65ZD9
  • KD-49XD8305
  • KD-43XD8305
  • KD-55XD8005
  • KD-49XD8005
  • KD-43XD8005
  • KD-49XD8077
  • KD-43XD8077
  • KD-49XD8088
  • KD-43XD8088
  • KD-49XD8099
  • KD-43XD8099
  • KD-65XD7504
  • KD-65XD7505
  • KD-55XD7004
  • KD-49XD7004
  • KD-55XD7005
  • KD-49XD7005
  • KD-50SD8005
168 RISPOSTE 168
ErVikingo
Se la funzione Motionflow di default è disattivato, le ho per entrambi, ovvero, sia con l'XE e l'XG non ho mai impostato nulla a riguardo.
Il fatto è che l'XE va meglio dell'XG, più fluido su tutto, al contrario della qualità immagine, l'XG è più nitido e limpido.
Allora forse il problema è nella qualità del segnale dall'Antenna, dati che sono anche in due luoghi diversi.
Nejiros
Ma ancora con questo problema?Non c'è nessun problema, è solo lenta, tutto qua.....parlo di canali di tivusat in cui ho segnale pieno, non centra nulla quindi la ricezione del segnale.
sonysta
Campione
@Bruxk120
Mi sa che l'hai presa troppo sul personale...il mio era un discorso in generale e non sapevo neanche chi aveva sollevato la questione dato che la lentezza cambio canali viene spesso riproposto non solo qui ma anche in parecchie altre discussioni ho pensato di dire la mia.Nessuno ti ha accusato di voler spingere per un marchio o per un altro e nessuno mette in dubbio la tua "fedeltà" a Sony. Non di certo io.
ap2001
Io ho un AG9 e posso dire che è veloce nella navigazione e tutto il resto, ma è abbastanza "lento" nel cambio canale del digiale terrestre. Ho digitale terrestre anche sullo Sky Q e la velocità del cambio canale del box Sky è superiore.
Ma sono due sistemi operativi completamente diversi per cui non paragonabili, anche l'hardware dei 2 device sono completamente diversi. Resta comunque il dato di fatto che che su Android il cambio  canale su DTT è più lento.
Una curiosità, se premete il tasto del Canale scelto e poi uno di "conferma" come "Ok del Tasto centrale" il cambio Canale si velocizza?
sonysta
Campione
@Marino.Manolo
Si praticamente è immediato.Altro motivo per cui...etc.etc.
ap2001
No, non cambia nulla. Se io faccio CH+  passano 3 secondi (circa) per vedereil canale successivo.
Se invece scrivo 5+OK sempre 3 secondi (circa) ci vogliono prima di vedere e sentire il canale desiderato.
sonysta
Campione
Se digito il numero di canale e poi ok il passaggio è quasi immediato!
Nejiros
Cmq per farla breve almeno io non volevo sollevare nessun caso, la TV non ha nessun difetto, mi da solo fastidio quando si vuole negare l'evidenza, la TV è lenta sia nel cambio canali che nella navigazione dei menù, è un dato di fatto, adesso la colpa può essere di Android che non è ottimizzato e tanti altri motivi, rimane il fatto che è lenta se paragonata ad altre tv(anche Android), se qualcuno la pensa diversamente rispetto il suo pensiero, certo non me ne faccio un  problema, è così e come ripeto non è un difetto, tutto qua......la tv la uso praticamente come monitor in quanto ho una sorgente collegata alla hdmi e faccio tutto da li, ho esposto semplicemente un dato di fatto, cioè che è lenta, tutto qui....
