TV BRAVIA - Aggiornamento del firmware alla versione 6.6555
https://www.sony.it/electronics/support/lcd-tvs-android-xf90xx_x90xxf-series/kd-49xf9005/downloads/0...
Vantaggi e miglioramenti dall'aggiornamento precedente
  • Migliora la reattività del TV all'accensione dalla modalità standby
Modelli applicabili
Queste informazioni sono valide per i seguenti modelli di TV:
  • KD-43XG8305
  • KD-49XG8305
  • KD-49XG8377
  • KD-43XG8388
  • KD-49XG8388
  • KD-43XG8396
  • KD-49XG8396
  • KD-43XG8399
  • KD-49XG8399
  • KD-49XG9005
  • KD-55AG8
  • KD-65AG8
  • KD-43XG8096
  • KD-49XG8096
  • KD-55XG8096
  • KD-65XG8096
  • KD-75XG8096
  • KD-43XG8196
  • KD-49XG8196
  • KD-55XG8196
  • KD-65XG8196
  • KD-65AF8
  • KD-55AF8
  • KD-75XF9005
  • KD-65XF9005
  • KD-55XF9005
  • KD-49XF9005
  • KD-65XF8796
  • KD-55XF8796
  • KD-49XF8796
  • KD-43XF8796
  • KD-65XF8599
  • KD-55XF8599
  • KD-49XF8599
  • KD-43XF8599
  • KD-85XF8596
  • KD-75XF8596
  • KD-65XF8596
  • KD-55XF8596
  • KD-49XF8596
  • KD-43XF8596
  • KD-65XF8588
  • KD-55XF8588
  • KD-49XF8588
  • KD-43XF8588
  • KD-65XF8577
  • KD-55XF8577
  • KD-49XF8577
  • KD-43XF8577
  • KD-65XF8505
  • KD-55XF8505
  • KD-49XF8505
  • KD-43XF8505
  • KD-70XF8305
  • KD-60XF8305
  • KD-55XF8096
  • KD-49XF8096
  • KD-43XF8096
  • KD-65XF7596
  • KD-55XF7596
  • KD-49XF7596
  • KD-43XF7596
  • KDL-49WF805
  • KDL-43WF805
  • KDL-49WF804
  • KDL-43WF804
  • KD-77A1
  • KD-65A1
  • KD-55A1
  • KD-75XE9405
  • KD-65XE9305
  • KD-55XE9305
  • KD-75XE9005
  • KD-65XE9005
  • KD-55XE9005
  • KD-49XE9005
  • KD-75XE8596
  • KD-65XE8599
  • KD-65XE8596
  • KD-65XE8588
  • KD-65XE8577
  • KD-65XE8505
  • KD-55XE8599
  • KD-55XE8596
  • KD-55XE8588
  • KD-55XE8577
  • KD-55XE8505
  • KD-55XE8396
  • KD-55XE8096
  • KD-49XE8396
  • KD-49XE8099
  • KD-49XE8096
  • KD-49XE8088
  • KD-49XE8077
  • KD-49XE8005
  • KD-49XE8004
  • KD-43XE8396
  • KD-43XE8099
  • KD-43XE8096
  • KD-43XE8077
  • KD-43XE8005
  • KD-43XE8004
  • KD-100ZD9
  • KD-75ZD9
  • KD-65ZD9
  • KD-49XD8305
  • KD-43XD8305
  • KD-55XD8005
  • KD-49XD8005
  • KD-43XD8005
  • KD-49XD8077
  • KD-43XD8077
  • KD-49XD8088
  • KD-43XD8088
  • KD-49XD8099
  • KD-43XD8099
  • KD-65XD7504
  • KD-65XD7505
  • KD-55XD7004
  • KD-49XD7004
  • KD-55XD7005
  • KD-49XD7005
  • KD-50SD8005
168 RISPOSTE 168
sonysta
Campione
@Flamerone
Lo so che è cosi e come te non capisco il motivo. Beh se poi pur di aver un cambio veloce si accontentano di un TCL allora...condoglianze!
Bruxk120
Vorrei chiarire che il sottoscritto acquista TV SONY dal 1995 (2 a tubo catodico e 3 LCD) e non cambierebbe questa marca con nessun'altra perché la ritengo superiore per la qualità dell'immagine a tutti gli altri brands.
In questo momento ho in casa il modello 22EX320 e il nuovo 43XG8396.
Nel mio caso specifico, quando ho "osato dire" che il cambio di canale mi sembrava lento, l'ho detto perché ho fatto il confronto con i TV che possiedo attualmente e con tutti gli altri che ho avuto precedentemente escludendo naturalmente quelli a tubo catodico che non sono paragonabili ovviamente.
Prima del 43XG8396 avevo un 32W4000, apparecchio del 2008 e sicuramente lo zapping era più rapido come lo è sul 22EX320 ma è solo, ripeto, una constatazione di fatto ma sicuramente dicendo questo, almeno nel mio caso, non sto rimpiangendo un TLC e/o qualsiasi altra marca per i motivi che ho sopra detto.
Inoltre come ultima osservazione, voglio aggiungere che è il primo TV Android che acquisto e non ho avuto occasione di confrontarlo con altri modelli android e quindi mi rendo conto che magari la "lentezza dello zapping" da tanti lamentata magari è dovuta anche ala presenza di android anziché altri sistemi (sono troppo inesperto per poter giudicare).
Chiusa questa parentesi, tornando all'aggiornamento firmware, voglio segnalare invece che quanto affermato dalla Sony relativamente all'utilità dell'aggiornamento  (Migliora la reattività del TV all'accensione dalla modalità standby) si è dimostrato vero perché secondo il mio modesto parere effettivamente il televisore è più rapido all'accensione.
Mi scuso per la lunghezza del testo e saluti a tutti.
ErVikingo
Mi inserisco per fare una domanda che non ha a a che fare con l'aggiornamento.
Vorrei sapere da cosa potrebbe dipendere il continuo micro scatti nei titoli di coda,( la striscia inferiore dove scorrono le varie informazioni), da destra verso sinistra.
Lo dico perché tra l'XE e l'XG, c'è una notevole differenza, l'XE è molto più fluido, anche se è un modello di due anni più "vecchio".
Avevo pensato al tipo di CPU, ma dovrebbe esser il medesimo.
Forse hai le impostazioni del "Moto" regolate diversamente?
Nejiros
Cmq spesso si tende sempre a difendere il prodotto che uno ha in casa e molti parlano per partito preso.....ogni volta che uno riporta un difetto gli si affibbia subito l'appellativo del fissato, invece non è sempre così.......Io non ho nulla contro Sony(anzi tanto di cappello a un marchio che ha portato tantissime innovazioni ecc...)e non ho nulla nemmeno contro la mia AG8, però se c'è una cosa da dire la dico....La TV è lenta nel cambio canali e in generale nello spostarsi tra i menù ecc..? Risposta:SI È LENTA, punto! Non si tratta di nessuna fissa, ho altre due tv in casa(tra cui una Philips con Android) e nel corso degli anni ne ho cambiate diverse ma non lo considero un difetto, aspettare qualche secondo in più nello spostarsi nei menù e nel cambio canali non è la fine del mondo, importante che la qualità in generale sia ottima e su questo non ho nulla da dire al momento.......
Tag (1)
La "lentezza" del Sistema dipende sia dal Processore che dell'ottimizzazione del Sistema Operativo ed AG8 non è AG9.
Le tue due TV, tra le quali la Philips Android TV sono 4K?
Nejiros
Certo che è una 4k la Philips, è una 43 pollici del 2018......ovvio che tra le due preferisco la Sony su tutti i fronti, si stà solo parlando di lentezza non di altro.......e ripeto non lo considero un difetto ma dico le cose come stanno.
Non ti sei chiesto il perché della domanda sul 4K (non ho verificato se Philips ha FullHD Android TV), non per affermare la migliore qualità, lo domandavo per via del fatto che il cambio Canale potesse essere meno rapido in un 4K, vista la quantità di informazioni in più, rispetto ad un FullHD.
Provato a disabilitare, nelle Impostazioni del Digitale, ciò che di Interattivo può essere su ON.
È una prova che vorrei fare quella di verificare ogni voce del MENU dei Canali Digitali...
Nejiros
Si, le ho disabilitate quelle funzioni, poi ci riguardo.....cmq ripeto di nuovo, non è un difetto, Android a me piace tantissimo.....
Trovo anche fuori luogo sempre il paragone con la AG9, l'AG8 è pur sempre una tv da quasi 3.000€ di listino......Su Android secondo me ciò che influisce maggiormente sono le personalizzazioni che ogni brand fa a modo suo....Ti faccio un esempio, ho un P30 Pro che secondo me è un telefono eccezionale in tutti i reparti, un P30 Lite a velocità mica è inferiore al mio ha solo delle cose a livello hardware inferiori come fotocamera, processore, ram ecc....e sono quelle le cose che determinano il prezzo, come per AG8 e AG9......tra l'altro non conosco la AG9 e nemmeno sò se nel cambio canali e nella navigazione dei menù è uguale a questa....
No non dico che AG8 sia da scartare anzi, ma se parliamo di prestazioni dobbiamo considerare anche la scelta dell'aggiornamento ad Android TV 9, ancora maggiormente ottimizzato, e dettata da una superiore capacità del SoC, altrimenti anche AG8 sarebbe aggiornabile.
Sui prezzi non discuto mai se non per ribadire che il prezzo è sicuramente alla base delle scelte ingegneristiche, che possono essere a loro volta alla base della reattività.
