WH1000-XM3 volume issues over bluetooth
SOLVED
larister
New
Hi,
I have some XM3s and love them; however there's a weird issue I can't track down. I have a Macbook Pro (15-inch 2017 running High Sierra) and when playing music over bluetooth, I often find the volume is significantly quieter then it should be.
If I pause the music by doubletapping the right ear, I hear the volume correct itself for an instant just before the pause kicks in. Unpausing then continues playing at the right volume. The same issue exists when playing music connected to my iPhone 7 as well.
Has anybody else experienced this? Obviously the quick fix is not too onerous, but it'd be good to understand why this is happening.
Thanks in advance.
Tags (2)
1 ACCEPTED SOLUTION
Accepted Solutions
Sean_Mc
Moderator
Hi Alastair,
It might be best getting in touch with the Sony Support team here who will be best to advise you further.
Best wishes,
Sean
3 REPLIES 3
Sean_Mc
Moderator
Hi there,
Welcome to the Sony Community.
Have you tried adjusting the volume from the app?
Best wishes,
Sean
larister
New
Hiya Sean,
Thanks for your reply. I can adjust the volume from the app when it's
connected to my iPhone but that doesn't solve my problem here. The
workaround of simply pausing and replaying by tapping on the right ear
phone is easier then opening up a separate app. Also it doesn't solve my
issue when connecting via the MacBook.
Cheers,
Alastair
Sean_Mc
Moderator
Hi Alastair,
Best wishes,
Sean
