Personally I think the NC on the Wh-1000xm3 I recently purchased is poor, I am currently on train can here the noise of the train, people chatting and the announcements. Not what I would expect that for nearly £300
Exactly my critiques. With my previous version headphones I used to be able to sit on a train with nothing playing and NC was practically flawless.
With the xm3s I have no choice but to play something relatively loud to drown out background noise regardless of NC.
If anything it accentuates a lot of noises I’d normally never notice without wearing the headphones. It’s utterly infuriating and I can’t see myself staying with the brand after this pair.
I’ve read that certain firmware updates have caused some NC problems but I don’t personally know that for sure.
I reckon they know the NC capability has deteriorated and this is why they are claiming this is how it should be.
Hi mines are the same. NC very poor I primarily bought these for their NC capabilities on an aeroplane as I cannot stand the noise of crying children. Engine noise, people talking, children crying all sounds were very clear and I would get better results with good pair of ear plugs. Sent headphones to Sony for repair and or upgrade but returned saying all was as it should be. Very very disappointed with this product and also Sony's advertising and marketing of this as noise cancelling as it's clearly not.
Sony engineers report
Hello @RobertGourlay,
please take a screenshot and not a photo of the screen.
This is barely readable.
- Nic
Thank you, the strap line 'just your music nothing else' surely breaches advertising guidelines.
Hi did you manage to get the NC issue sorted out
Thanks
Can you show the settings on the app? If you look at the second screenshot where the train is selected, this is the most quietest NC mode, cycle through the tabs on top where it shows sitting, walking, running and transport, if you can’t tell a difference between them then you may have a problem. The app looks and works identically on Android and iOS.
