Replacement Extension Cable for MDR-AS40EX
SOLVED
profile.country.en_GB.title
char615
Visitor
I accidentally broke the 60 cm extension cable that comes with MDR-AS40EX active series earphones. Does anyone know a reliable source to get a replacement that is not extortionately priced?
Thanks a lot,
Char615
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi Char615,
Forget the post above you should be able to purchase an replacement extension lead (part number 183495811) from  http://www.4ourhouse.co.uk/cgi-bin/home.pl..
2 REPLIES 2
Thalamus.
Champion
Hi Char615,
welcome to Questions & Answers..:smileyhappy:
You may be able to order this from either your local Sony Centre or alternatively try Sony's dedicated spare parts provider Nedis..
Thalamus.
Champion
Hi Char615,
