Replacement earpads for mdr-ma900 Headphones
SOLVED
strobin63
New
Can anyone help with. Replacement earpads for Sony MDR-MA900 headphones. I have trawled the internet without luck :slight_frown:
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Have done some investigating for you..:smileyhappy:
It seems spares are limited as the headphones are quite new but you should be able to obtain replacement ear pads from  http://www.4ourhouse.co.uk & the part number should be 429674101..
5 REPLIES 5
Thalamus.
Champion
Hi  strobin63,
welcome to Questions & Answers..
You may be able to purchase replacement ear pads from Brighthouse
strobin63
New
Thanks for the reply Thalamus. The phones are not listed on their search engine. But I will email them.
If anyone can find any on the internet. I would be grateful - I can't !!!!!!!
Thalamus.
Champion
If Brighthouse can help, let me know & I'll try and check with one of our Sony contacts to see if they can help..
strobin63
New
OK Thank You.
Thalamus.
Champion
