Pairing Sony Walkman NW-A55L to Pure CF-6 via Bluetooth
SOLVED
virgil7
Explorer
Hello there .. I am trying to pair my new Sony Walkman NW-A55L to my new Pure CF-6 via Bluetooth without success. I have also tried to pair it with my Roberts Blutune to no avail.
I have followed all the instruction manuals but am still at a loss.
Does anyone have any suggestions, preferably clean :slight_smile:
Virgil.
1 ACCEPTED SOLUTION
Accepted Solutions
virgil7
Explorer
I finally managed to connect it Nic ... Tools - Settings -Connect to/Add Audio Device - Wireless Playback Quality
Then 'tap' aptX.
10 REPLIES 10
profile.country.DE.title
IamNic
Hello @virgil7,
are the devices you try to connect your Walkman to in pairing mode?
They need to be, otherwise they are not discoverable by the walkman.
- Nic
virgil7
Explorer
Hello Nic, yes they are both in pairing mode with the Bluetooth icon showing.
There's obviously an easy answer to this but if I don't know then it is quite baffling.
IamNic
Hello @virgil7,
how far do you get when pairing? Does the player simply not discover the CF-6?
- Nic
virgil7
Explorer
Affirmative Nic - the player does not discover my Pure Evoke CF-6 or even my Roberts Blutune 100.
IamNic
Hello @virgil7,
then maybe the radio you have doesn't support the right bluetooth protocol.
Can you pair other radios/headphones?
I can pair all my speakers+headphones I have at home with my NW-A45, I doubt the protocol is much different to the ones on the NW-A55.
I unfortunately can't get my hands on a 55, otherwise I would check.
- Nic
virgil7
Explorer
Hello there Nic, yeah, I was thinking along the same lines .. I've tried just about everything, read all the instruction manuals, including on-line, watched a few videos etc. etc.
I can't pair the Walkman  with my Roberts Blutune 100 either, so it looks like the Walkman is going back to Amazon.
Thanks for your efforts my friend.
Ray in Cornwall, UK.
IamNic
Have you considered to get the NW-A45 instead?
- Nic
virgil7
Explorer
I'll make a decision over the weekend, nic. I'm also checking out the Fiio M9 and the Cowon Plenue D2.
virgil7
Explorer
Hello nic .. I purchased a FiiO M9 in the end, and it connected to my Pure Evoke CF-6 music system straight away.
So you were correct in thinking maybe the Walkman and the Pure Evoke used different protocols.
The Walkman NW-A55L uses Bluetooth 5.0 whereas the FiiO M9 uses Bluetooth 4.2
