NWX-B162/B163/B162F/B163F walkman
kagordo31
New
I have a walkman that I find easy to use and did a lot. Now I cannot find the software so that I can update my playlist.
Does any one know how I can get hold of this software so I can use my walkman again.
many thanks
3 REPLIES 3
jumpsuit
Hi @kagordo31 and welcome to the Community :slight_smile:
Did you mean the NWZ-B162?
Which software were you looking for?
The supplied software is on the Walkman,
the manual says:
"The software is stored in the built-in flash memory of the player, and includes the
following items:
WALKMAN Guide
User Guide, etc.”
joharve9836
New
Yes, I can see that the software should be in the product.  However the guide indicated that the device could be re-formatted to increase the user space for audio.  I have not used this product for some time and I guess that I must have deleted the requested file.  Do you know if Sony have a copy themselves that they could let me have?
Any help on this will be appreciated.
You can use Windows Media Player, also in Windows 10...
