MDR-DS6500 connection method
SOLVED
profile.country.en_GB.title
brijoco
Visitor
Which type of cables are utilised to connect the MDR-DS6500 base station to a Bravia TV or BD player?
Tags (3)
1 ACCEPTED SOLUTION
Accepted Solutions
Thalamus.
Champion
Hi brijoco,
depending on the ports you have on your Bravia or BD player you should be able to connect your MDR-DS6500 base station using either the supplied Optical digital connecting cable (see below)
Or by purchasing a set of audio cables as show below..
1 REPLY 1
Thalamus.
Champion
Hi brijoco,
