Screen Cleaning and DVDR drive question
gvelon
Visitor
Hello everyone!
I am sure that I'm not the first to post questions like the following but I would greatly appreciate if you could help me or point out any answer already posted.
I have 2 questions:
1) What is the most efficient way to clean a vaio (FS215s) x-black screen? Is it possible to remove those tiny spots that appear due to talking coughing etc facing the screen?
2) a more serious one: I know that my SONY DVD RW DW-D56A is specified to be able to burn DVD+R at 8x speed. Why can I only burn at 4x speed. Is it the drive, the software or the DVD disks responible?
Thank you in advance for your time
George.
5 REPLIES 5
profile.country.en_GB.title
kee-lo_
Member
1) There's an active topic about this in the solutions room
2) Are you using 8x certified media?
gvelon
Visitor
Yes I am sure that all disks I use are 8x certified? :thinking:
maybe I should use sony brand dvd's
krige
Visitor
1) What are acceptable cleaning agents for cleaning my LCD Screen?
* Water
* Vinegar (mixed with water)
* Isopropyl Alcohol
* Petroleum Benzene
What are some of the basic supplies needed to clean an LCD Screen?
* Always use a soft cotton cloth. Some materials, such as paper towels or old rags could cause scratches and damage the LCD screen.
* Computer wipes. Only use these if they specifically state on the package they are designed for LCD laptop screens.
What are proper cleaning techniques?
* Do not spray any liquids on the LCD screen directly. Always apply the solution to your cloth first, not directly to the parts you are cleaning.
* Stroke the cloth across the display in one direction, moving from the top of the display to the bottom.
What are Unacceptable Cleaners?
* Acetone
* Ethyl alcohol
* Ethyl acid
* Ammonia
* Methyl chloride
2) the DVD disks are responsible.
Thalamus.
Champion
I use Verbatim and Emtec, no problems with them
I also use Verbatim and I use Sony both are DVD +
kee-lo_
Member
