Hi all again ok got my modem instaled for broadband works great problem is i now have the icon to safely remove hardware desktop icon up all the time and cant get rid of it it just lets me remove it ?????
any help
As far as I know the only way is to right-click the notification area, and selecting Properties. Under the Notification area heading, click Customize. Find the Safely Remove Hardware icon and select Always hide in the Behavior column next to it (press OK and Apply to back out).
Try that
Try that
The only reson you have that is because you have a plug and play device, meaning you can unplug the modem anytime by safely removing it first.
As Snipes says it should hide it.
Anytime Madxbri,
thank you two i thought i had set something wrong but i havent :smileygrin: thanks Kee_lo for that info i have hidden it now as it looks messy and i dont plan on taking the modem of but i will remember just incase i do
again thanks this site just gets better and better its a shame sony cant when you phone them for help it dissapoints me so much that the buyers know more than the sellers
at least someone knows thou
They just don't make time to learn about it, silly really...
True, but it is worrying to think "well what if I had a problem Sony had no idea of and they screw me around for months on end", unsettling...
