Options menu can't be viewed when watching blu ray
Clarkescott
Explorer
I purchased a KD55XE7002 TV but when watching a blu Ray I'm unable to adjust picture or sound settings as the options menu on the Sony remote only invokes the options menu on my Samsung blu ray player. I have to go back to the digital av source makes changes and then restart the blu ray....there must be an easy fix.
3 REPLIES 3
Sean_Mc
Moderator
Hi Clarkescott,
Welcome to the Sony Community.
Are you able to use other functions on the TV remote to control your Blu-ray Player?
Thanks,
Sean Mc
profile.country.DE.title
IamNic
Hi @Clarkescott,
there should be an option on the Blu-Ray Player, which deacitvates the function to control it via your TV remote.
Then you can adjust the picture settings and re-enable the function if you desire to do so.
- Nic
Clarkescott
Explorer
Hi Sean, I turned off the Anynet+ option on my Samsung blu ray and now the TV menu appears. I was hoping that I would have the option 'mastered in 4k' showing within the TV picture menu but it remains greyed out. I suppose that is a problem for another day.
Thanks for your help
