In xperia tipo red border appers while doing sometimesss...................and it is too difificult to take sim and memory card out...can damage the slotss..................is that a common problem or waht....tell me ??
Solved! Go to Solution.
i did a factory reset and the problem is resolvedd....................:smileywink:
And there is another problem it is not reading any memory card m confused what to doo??
can you show a screenshot of the problem?
if your device is new, the slots would still be difficult to work with, eventually it will loosen up.
have you tried to test the memory cards on other phone?
try reformatting the memory cards,
Settings > Developer options > remove check on Strict mode enabled.
