can Old sim cause any problem?
SOLVED
Dasun
Visitor
I have a Sony Xperia U phone!
can my Old sim card cause any problem? problem like this [picture] ?
It repeats two number ex - .. 3 4 5 7 7 8 .. [ no 6 ] and It changes with time ...
screenshot_2013-03-31_2104.png ..... ?
should I use a new sim card ?
1 ACCEPTED SOLUTION
Accepted Solutions
Samuel1
Hero
I don't think this is related to the SIM-card. Try repairing the phone software via PC Companion at first.
http://www.sonymobile.com/update
By the way, how old is your SIM-card?
6 REPLIES 6
Samuel1
Hero
Dasun
Visitor
not sure .. may be ... 4 or 5 years old ..
but It sitll works fine with my LG Phone (not android) !!!
Samuel1
Hero
Well, in that case I'd recommend that you replace it anyway, since old cards can cause issues. Also, they generally don't support the newer network bands as well, so it could improve your network coverage.
Dasun
Visitor
thank you very much sir  Slightly_smiling_Face ..
can you be sure this problem isn't related to the SIM-card ?
Samuel1
Hero
Well, you could try it but I doubt it will solve the issue.
draganz
Visitor
yako oka ube sim eke awlak newei. oka Gingerbread wala awlak...uba dan oka hamathanama daanawa..ochchara awlak nam ICS flash karapanko? mageth gingerbread kaale oka thibba.. Dizzy_Face
