- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
build no. 15.1.C.1.17
model no. c1904
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Try to clear data for Walkman player under settings > apps > all > Walkman > clear data. Restart phone and try again.
If you still experience problem I suggest that you free as much RAM memory you can in the phone, swipe recent used apps to the side, don't use live wallpaper and remove some widgets from the home screen. Try again.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi, have you tried repairing phone software with PC Companion or Update Service?
http://www.sonymobile.com/gb/tools/pc-companion/
http://www.sonymobile.com/gb/tools/update-service/
Be aware that this process will erase phone data completely, backup if necessary.
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
And by the way i am considering to repair the phone via pc companion thanx gwhispererz for the Info.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Welcome! Have fun with repairing phone software. :smileysmileywink:
