The problem might be a faulty/old SIM card, what if you get a new SIM card?
Hi!
I am facing the same problem here on M4 Aqua. SIM1 which has a new nano sim gets disabled automatically and I have to restart the phone to get it working. Today it happened while I was on a call and this is absolutely frustrating. I am not sure if this has to do with another SIM lying in SIM2, which is disabled by default. Since its a roaming SIM (SIM2), I only enable it on need basis.
Any ideas / thoughts what could be done?
Regards,
Anand.
