Sony X950H TV - 'Click' sound when turn ON/OFF
SOLVED
profile.country.RO.title
Agent_F
Explorer
Hi,
I bought a  new TV, X950H and when I turn ON and OFF the TV a ‘click’ sound is hearing from the back of the TV, sound like you are turning on/off a PC.
Is that usual for latest Sony TV’s? Because I have an old one and no sound is present.
I had also Samsung TV's and no sound was present when turning ON and OFF the TV.
Thank you.
1 ACCEPTED SOLUTION
Accepted Solutions
Hi there,
This is the LED panel turning ON and OFF.
No need to be worried!
Have a great day! :slight_smile:
6 REPLIES 6
Agent_F
Explorer
No one has the same issue? It is a hardware problem?
Win_88
Specialist
Agent_F
Explorer
Hello,
Thank you for the answer.
I am aware of those kind of sounds caused by thermal expansion and contraction of the internal panel components and I don't have a problem with that.
My problem is that just when I push the 'turn ON/OFF' button from the remote, a 'click' sound is present behind the TV. It's like you are turning ON an OFF a PC.
That sound I don't know if is normal or not.
Hi there,
Agent_F
Explorer
THANK YOU
Joe_Dohn
Specialist
@nikxivanov
Thanks a lot for the clarification, it's really helpful.
@Agent_F
It'd be really helpful if you mark the thread as solved so that others with the same question can find their answer easily ^^
