Programme guide on KD-43E8004 has begun to display NO INFORMATION AVAILBLE on HD setting.
SOLVED
fredmacdonald
New
43XE8004 prog guide just begun to display message 'No Information Available' only on HD setting.
1 ACCEPTED SOLUTION
Accepted Solutions
fredmacdonald
New
Yes I discovered the reason. I rebooted the TV. To do this switch the TV on then press down the green on/off switch and hold for 8 seconds. Take your hand/finger off the switch button and the TV will switch off then it will reboot itself and you'll see pretty patterns in the centre of the screen for a while after which it will switch itself back on and , hey presto, the guide is back complete.
3 REPLIES 3
fredmacdonald
New
Mick_D
Moderator
Hi @fredmacdonald, welcome to the Community.
Sorry to hear this. It's likely only a temporary issue; if you're still experiencing it, just reset the TV: unplug the power cord from the power outlet and wait a few seconds to plug it back in.
Hopefully that will resolve the issue.
Cheers
Mick
fredmacdonald
New
