I turned my TV on 4 hours ago and it went into update mode which in the past has taken 5-10 minutes (if that)
It is still processing and appears not to be getting anywhere. It moves from the update screen (all multi-coloured moving images) which runs for 10 secs to 60 secs, turnes itself off (LED light "on" light disappears) and then turns itself back on and the SONY sign appears. A few seconds later the update images appear again.
Looks to be in a constant loop.
Can anyone help?
Ian
Hi there,
Have you tried a factory reset?
Best wishes,
M
Hi I’m having the exact same issue! I’ve had this tv now two years and over the last week it’s been stuck in this mode of the android logo appearing,freezing and then the tv restarting. I’ve tried multiple hardware resets but still nothing. I’ve contacted Sony but still no further forward 😞
I could not carry out a factory reset as the TV would not respond to the remote of power off at the back - in a continual loop.
I contacted Sony and they emailed me a procedure - I guess like cntl/alt/delete on a computer - detailed below. This worked on the 2nd attempt and effectively was a factory reset. i then had to go through the set up as if a newly delivered TV
Thanks Ian I will try that. I’m getting nowhere with Sony I hope I can get this fixed. A two year old tv and this happened,not impressed.
I tried this yesterday with no luck 😞 Has anyone any further suggestions or something else I could try? Really don’t want to have to buy a new TV!
