- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Good morning folks,
I have the above television which is used with a Sky Q system with the main Q box on a shelf just below the television.Asl in the same room is a BT WIFI Booster.Router is outside in the passage. Every now and then the television displays a message"wifi has no internet access" So I have to renter the router code.All ok for a while and then the message appears again.My question is this Can I connect the television by ethernet power adapters to the router? If so are there any settings need changing on the television? .Presume the q box woul d just require the router password.
Many thanks in advance
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@dnicho Hi.I reckon I,ve solved the problem now.I used 2 TPL power adapters. One for the television and the other for the router.Switched everything back on and after about 5 or 6 hours now all seems ok. with no messages appearing. Television recognised the adapter straight away with no further setting up. I'd tried various options buyt this is the only one that has worked.I will consider this problem solved.Hope this helps you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
