bomber514
Explorer
Bravia KD43XF8796 wifi no internet
Good morning folks,
I have the above television which is used with a Sky Q system with the main Q box on a shelf just below the television.Asl in the same room is a BT WIFI Booster.Router is outside in the passage. Every now and then the television displays a message"wifi has no internet access" So I have to renter the router code.All ok for a while and then the message appears again.My question is this Can I connect the television by ethernet power adapters to the router? If  so are there any settings need changing on the television? .Presume the q box woul d just require the router password.
Many thanks in advance
Who Me Too'd this topic
