After assigning any function to AEL button by Operation Customize> Custom key /Dial setting, when I press AEL button, the display returns to menu Operation Customize> Custom key /Dial setting and the function selected is not performed. Any suggestion?
Hey Pepsus, could you upload photos of the menu?
Thank you for the reply. I uploaded two photos of menu. In the first one I tried to assign to AEL button AEL hold . When I press AEL button the result is what you can see in the second photo. The menu returns to custom Key/dial set. The same occurs with any function I assign to AEL button function.
Hey Pepsus, maybe the camera is glitching, try removing the batteries and test, then try reset and test again. Let me know if that works.
