Sony A35 Problem
SOLVED
stuboy-69
Explorer
Sony A35 Problem
Hello
I have purchased a second hand Sony A35 and seem to have a problem.
It seems to be stuck in fast/multiple frame option, I have tried to chance the setting in the menue options but the drive icon is grayed out and can not be selected.
Any ideas how to sort this out?
I have turned the dial to different modes but all the same, any info really appreciated!
Cheers
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
Mick2011
New
Hi stuboy, welcome to the Sony Forums :slight_smile:
Try a hard reset: power off, remove the battery, press and hold the shutter release for 1 minute, replace the battery and power on. This should restore all settings to factory defaults and hopefully rectify the problem.
Cheers
Mick
1 REPLY 1
Mick2011
New
Cheers
Mick
