I would like to make some moulded foam inserts for a case for E-mount lenses and I'm trying to find the exact external measurements of the lenses including the rear lens cap. I had assumed that the measurements on the website would be accurate but I'm not sure they include the mount. Does anyone have any experience of this?
Hi there,
Hopefully a community member has had some experience with this.
Best wishes,
M
Hi bobbycornford,
If you let us know the model number of the lens, we can try looking for an answer with you.
Win_88
