Xperia Z2 LED notification not working
SOLVED
Dante7ist
Visitor
Few days ago I noticed my LED notification is not working anymore and I did not apply any changes nor I downloaded some new apps and instead of that my screen turns on when I get any sort of notification. How can I fix this issue ?
Thanks for advice, Dante
1 ACCEPTED SOLUTION
Accepted Solutions
Dante7ist
Visitor
OK I found what causing this... it was permission for clean master to read notification on lockscreen when I disabled that in settings now it works perfect like it was before
5 REPLIES 5
profile.country.PH.title
MarlonUk1
does it work while you are on safe mode?
how about on xperia diagnostics? settings>about phone
Dante7ist
Visitor
how to turn on safe mode ? and what exactly I have to do with that diagnostic settings ? there is no option for testing LED notifications
Dante7ist
Visitor
soo I tried secret menu code service test for LED/illumination green,red,blue works fine I always use vibration mode and it works perfectly fine before now I dont get LED notification from messenger, facebook, gmail, twitter, SMS and yea I checked that I have it turned on in settings also I have enabled all notifications in messenger last thing I tried to do is just simply restart phone but same result nothing changed I really dont know where is issue maybe I will try to uninstall some apps
EDIT: soo I figured out that there is no problem with LED but something cause to turns display on after any notification and I dont know where is root of this maybe recent update from some apps may be issue but I dont know how to troubleshoot it... as I said before I am using vibration mode most of time and before it worked fine dont remember doing some major changes on my phone that can cause this sort a thing
Dante7ist
Visitor
