What does this icon mean?
SOLVED
ickurs
Visitor
The icon is circled in the image below:
http://i48.tinypic.com/16c6uf9.png
1 ACCEPTED SOLUTION
Accepted Solutions
Aky1
Visitor
It mean your stamina mode is activated (turned on).
8 REPLIES 8
Aky1
Visitor
ickurs
Visitor
Thanks Slightly_smiling_Face
jatinrungta
Enthusiast
Isnt that the logo of avast antivirus??
Thinking_Face
gregorg1
Visitor
LOL!
Wrong answer marked as correct. Funny!
NO! This isn´t Stamina Mode indication. It´s the Avast AntiVirus for Android logo.
This means you have Avast installed and running.
Regards
xxxxxxxxxxxxxxxx
EDIT: I was wrong. Didn´t scroll.... My Fault! Sorry!
Nabeel
Master
gregorg1 If you look carefully, and scroll the screenshot to right( or even click on the photo to see it full), you'll see user has made a circle around an icon.
Aky and ickurs  it's extended battery mode.
Almost same thing though Slightly_smiling_Face
gregorg1
Visitor
Hey Nabeel,
I was wrong! ;-(
Sorry this forum seems to run on 1024 width.
Thank you.
Nabeel
Master
Be happy gregorg1 , it's not your mistake, that avasti antivirus icon + partial view of screenshot would confuse anyone
Cool. Slightly_smiling_Face
kentleejoon
Visitor
It's 2 hands  battery, showing care to battery, stamina mode
