Volume of music changes constantly with headphones plugged in
Zonky
Visitor
Hi guys,
I have android version 5.0.2 and since a couple of days the volume changes constantly from loud to silent with headphones plugged in. The headphones are the sport headphones from Philipps, but do not have any kind of remote control. I also tried to use other headphones same problem. I guess the Xperia has some kind of problem with remote controlling...
Did anyone had the same problem or knows how to fix it? Does anyone know how to turn off the remote controlling option?
Cheers,
Eric
5 REPLIES 5
Jake-SonyXperia
Champion
Hi Zonky,
Welcome to the community,
You should check the sound settings on the handset, as you may have an auto sound option turned on which is changing the audio levels.
Menu > Settings > Sound & Notifications > Audio Settings
Have a play in this section.
Let us know how you get on.
Pavel_V
Visitor
Hi!
I have got the same problem with my Xperia (5.0.2).
In addition to the aforesaid, the problem arises after you listening the music first (sound volume and sound quality - ok), then talking or playing by phone and after that I am trying to listen music again - the sound in hearphones becomes awful. Sound volume may be very loud and the same time, sound quality (bass, treble) becomes different settings and it is impossible to listen to music with such awful quality. Only phone restarting helps to return settings back (equalizer settings and type of earphones). I chose type of earphones proceeding from impedance parameters (Hifiman earphones). Please help.
Cheers!
Iamagain
Visitor
Hey guys, I had this problem 3 months ago. Your phones have broken jack ports, it also let's dust get inside the phone and makes the camera cover glass dirty from the inside. It was so annoying smart connect app kept going crazy, phone silencing volumes by itself and then after fiddling too much with the headphone connector it stopped working at all. A new jack connector for the phone is like £4 but I don't know how much they fit it for, mine was repaired by insurance company. Hope this helps. Peace
Harle
Visitor
Yes I noticed. Sony software seems to do automatic compression to your music. This is one of the many reasons  I'm switching to another manufacturer phone. The other two are. Turning down volume without even a prompt. And bad engineering on IP65. The o-ring that sits over USB port falls out and water gets inthrough USB micro port and kills display
Kindleshot
Visitor
It does it when my phone is fully charged and I have the charger pluged in, while using my headset. When I unpluged the charger, it stopped doing it!
