When I was on LP, I found the call shortcut from the lockscreen very useful. Now, after the 6.0.1 update, the icon seems to be replaced with the "OK Google" shortcut. Is there a way to get the callls shortcut back?
Solved! Go to Solution.
plz mention wat language i used..... or else dont be on this disciussion if it bothers u alot...
thnx alot buddy.... i got that prob solved...
Keep it friendly, here are the forum rules
http://talk.sonymobile.com/t5/Welcome/Discussion-guidelines/m-p/349678#U349678
Thanks. This also worked on 7.0 on my XA Ultra. Great to have my phone shortcut back on lock screen. So much more needed than Google search.
EDIT: Never mind. I was clicking on the wrong spot. You have to click on the word "Google" for it to work.
I don't know if something's changed in the menus since then, but that no longer works. When you click on "Assist & voice input", there is no option to set the assist app to none. Is there a new solution?
@alexdonwrote:Go to settings - apps, tap on the gear and select default apps. There, under assist and voice input, set assist app to none.
