I was at a pool today with friends, and decided to jump into water with my xperia Z and everything was fine, i was in the water few seconds then i got out and hour later jumped again for a few seconds. Everything was.just fine and after 2-3 hrs power/lock button stoped working. The only way to shut down the phone is by voluming up which did started to work like some sort of replica of power button? Should i bring the phone to retailer for fix or this could be softver problem bcause i didnt made an latest update?
Sorry for bad english and pls help. Thank you
Solved! Go to Solution.
Any estimation about the repair price if I were to send it to Sony for repairs?
At least the magnitude of it?
You need to give it time. Open all the ports, memory card, sim etc. Put it under a low heat spotlight and leave it there for a day.
