After updating my Z3 Compact to firmware version 23.4.A.1.200, when I use a navigation app my position (the dot) is displayed correctly but my direction (the arrow) is displayed towards the opposite direction. Navigating is not convinient anymore, because if I go North my devide believes I'm soing South and, therefore, gives me the wrong commands. ¿Is there anything I can do to fix it or do I have to wait for a new update that solves the problems caused by this one?
Solved! Go to Solution.
I've checked with Google Maps & HERE Maps and they work as expected. You could try to calibrate your compass sensor. Just look for any Compass app on Google Play. There are quite a few of free ones.
Another way to do it is going into Service Mode:
Enter *#*#7378423#*#* in the dialler.
Select "Service tests".
Select "Compass".
Follow the on screen instructions to calibrate the compass.
Hope it helps.
Select "Compass".
Hope it helps.
Thank you. Your tip seems to have solved the problem.
